Problems of executing JScript
Moderator: Administrator
cphan
Post by cphan »
I've tried to run the following script in Sable but it did not work. I've got the error message "One of the commands on the button failed to execute. XCommand: Execute Script:JScript.test()". Would you please help me solve this problem? Thanks!
function test()
    var rangeCount = GetNumberOfSubscriptRanges();
	for (var i=0;i<rangeCount;i++){
		var name = GetSubscriptRangeName(i);
		name = name.replace(/"/g,'\'');
		var elementCount = GetNumberOfSubscriptElements(name);
		for(var j = 0;j<elementCount;j++){
			var elementName = GetSubscriptElement(name,j);
			elementName = elementName.replace(/"/g,'\'');
Re: Problems of executing JScript
The following does not look right
Shouldn't it be something like
name = name.replace("g","a'');
cphan
Post by cphan »
According to the manual of Microsoft Jscript (http://msdn.microsoft.com/en-us/library ... 90%29.aspx), name.replace(/"/g,'\''); replaces " by ', am i wrong?
By the way, i remove 2 lines with "replace" methods, it does not work either.
The function works fine. But you don't return any value from it, so Sable assumes it must have failed. Try the following.
function test()
	return 1;
cphan
Post by cphan »
It works like a charm in Sable Developer!
However, it does not work with Sable Runtime, i have the error
"Error: Microsoft JScript runtime error
Error executing : x= test()
Reason: expected object
Text:
Line:3"
Thanks a lot for your help!
In Runtime, are you opening a SPK or the VNP file?
cphan
Post by cphan »
Neither of them works.
Can you send me the script file? The code works fine for me.
cphan
Post by cphan »
This is my project. Thanks for your help!
test.zip
(281.63 KiB) Downloaded 3633 times
What happens for you in Runtime? I click the button and the code executes correctly. The function you've written doesn't do anything that would show on the screen.
cphan
Post by cphan »
I reinstall Sable, it works now. Thanks again for your help!
