Adding macros to vensim
Posted: Tue Feb 18, 2020 12:36 pm
by neelu@nitw.ac.in
is it possible to add a macro program in Vensim so that production variable is changed a number of times within a time step?
Re: Adding macros to vensim
Posted: Tue Feb 18, 2020 2:14 pm
You might be able to do this with the SIMULTANEOUS function, or by using an array dimension as a virtual time axis.
What's the reason for doing this?
Posted: Wed Feb 19, 2020 7:29 am
by neelu@nitw.ac.in
please find the attached files.
I Have some questions about the model.
is the model is ok?
at the initial stage ( 0 months) demand is 300 and shipment is 50 the backorders are showing 0 instead of 250. this 250 has appeared in next month. if I want to get that 250 in the current month in an accumulation mode, how can I get it?
Similarly, FGI is equal to the production rate - shipment[/list][/list]
shipment is showing 50 due to the initial value of FGI is 50 but once shipment happens it becomes 0, please look in this issue.
Demand is 300 units /month, the production rate is also varies based on a cycle time suppose the products are taking 2 months as production time how can i use the delay function in this model?
Demand is 300 units/month but i want to get the production rate in terms of weeks like 1st week, 2nd-week production so that before completion of the month my required demand should be completed. is this possible?
Posted: Wed Feb 19, 2020 9:54 am
by LAUJJL
HI
Goto model, settings and change units and check 'use strict testing' and afterwards test unit dimension. you will see 7 unit errors. Correct them and it may reveal your error.
Posted: Wed Feb 19, 2020 10:09 am
by neelu@nitw.ac.in
LAUJJL wrote: ↑Wed Feb 19, 2020 9:54 am
HI
This is not clear for my questions
Posted: Wed Feb 19, 2020 10:18 am
by LAUJJL
The basic for good modeling is to have no unit errors; If you set model>setings>use strict testing' it will tell you your unit errors. Correct these unit errors and it may help you to find the other error.
Posted: Wed Feb 19, 2020 10:46 am
by neelu@nitw.ac.in
LAUJJL wrote: ↑Wed Feb 19, 2020 10:18 am
that's ok sir, but please answer to my another questions
Posted: Wed Feb 19, 2020 11:57 am
JJ is trying to help you. If you fix the errors, it will help.
We will not fix the model for you, but we do help you to fix it yourself.
Posted: Wed Feb 19, 2020 12:14 pm
by neelu@nitw.ac.in
I am very sorry sir, I am not asking you to fix the model but I want to know whether mentioned issues can we fix in Vensim or not?
if it is possible can you please explain sir
Posted: Wed Feb 19, 2020 3:00 pm
If you're interested in weekly dynamics, it seems like it would be easier to run the model in weeks.
I think the unit errors are closely related to the conceptual issues you're asking about. For example, you have:
production rate = start rate/cycle time
that transforms units/month into units/month/month, which doesn't make sense. Also, the rate-to-rate connection essentially makes the WIP stock superfluous. The simplest possible first-order equivalent would be:
production rate = WIP/cycle time
If you want to use a higher-order delay, you could use:
production rate = DELAY FIXED(start rate, cycle time, initval)
But again, if cycle time = time step = 1 month, the stock dynamics don't make any difference.
Posted: Wed Feb 19, 2020 3:02 pm
Your shipment equation also contains a unit error:
MIN((Back orders/delivery delay+Demand), FGI )
This takes MIN( units/month , units ) which is inconsistent. You don't need strict checking to discover this; you just need to correct the missing unit in delivery delay first (but JJ is right).
Posted: Wed Feb 19, 2020 3:04 pm
If you run the model in weeks, but you want shipments to happen discretely every 4th week, you can use PULSE TRAIN as a trigger for the shipments.
Posted: Thu Feb 20, 2020 7:31 am
by neelu@nitw.ac.in
tomfid wrote: ↑Wed Feb 19, 2020 3:04 pm
Posted: Thu Feb 20, 2020 7:33 am
by neelu@nitw.ac.in
neelu@nitw.ac.in wrote: ↑Thu Feb 20, 2020 7:31 am
Thank you very much sir
