initial value
neelu@nitw.ac.in
initial value
Post by neelu@nitw.ac.in »
Dear sir,
I want to get the backorders are started from the 0 instead of 1 with the accumulation in the given model so that I used simultaneous in the subtype of an auxiliary variable type. but it is memoryless variable.
How can I sovle this isuue in vensim.
I am very much thankful for your reply sir
back orders.mdl
(3.08 KiB) Downloaded 257 times
Re: initial value
I don't understand. When I run the model, back orders does start at zero.
I also cannot see any use of the simultaneous function.
neelu@nitw.ac.in
Re: initial value
in this model
demand at 0 is 278.684
Fill rate at 0 is 200
backorders at 0 are 0
backorders = INEG ( demand - Fill rate)
so I want backorders at 0 is 78.684. actually this appeared at 1
so how can I get this (78.684) at 0 and that should be accumulated for the entire simulation
please suggest any solution in Vensim for above-mentioned issue
even if I use the simultaneous equation for that issue but it is memoryless, so How can I do sir
Re: initial value
Your equation for back orders is
back orders = INTEG (demand-fill rate, 0 )
Change the "0" to "initial back orders" and give this a value.
initial back orders = 78.684
back orders = INTEG (demand-fill rate, initial back orders )
