Stumped on a stock and flow diagram D:
pinksuns
Newbie
Post by pinksuns »
Hello! This is my first time using Vensim with minimal knowledge prior and I've been losing my mind over this stock and flow diagram. I can't seem to get those slider things in my diagram when I run the simulation. I'm at a complete stump here :( Was wondering if anyone could look at the simulation and give me some tips on making it better. TYIA! :D
mydogmadethis.mdl
(5.02 KiB) Downloaded 251 times
Re: Stumped on a stock and flow diagram D:
Make sure you use the SyntheSim button. There are two, both green triangles on the top toolbar, the one to the right is SyntheSim.
put stricit units on in model settings and press ctrl U to verify your units. Start with a simpler model with only one stock first and once you have understood it add new elements step by step.
