Hi Tony,
Everytime when I tried to add a graph, sabel just stopped working. Can you please give me some help. Thank you!
sable stopped working
Moderator: Administrator
Re: sable stopped working
What version of Sable are you using?
And do you get a graph appearing on the screen at all, or does it crash immediately?
Thanks for your reply. My Sabel version is 5.1.468.0.
I can add a graph on the screen, but when I try to edit it (open its properties), Sable just stopped working.
I can view the properties ok. Are you selecting a certain property or tab?
I can even not choose any property or tab. When I right click the graph and choose property then it died.I attached my model, would you please take a look?Administrator wrote:I can view the properties ok. Are you selecting a certain property or tab?
- IDT model.rar
- model of Kai Wang
- (127.36 KiB) Downloaded 1960 times
Everything seems fine to me.
Can you explain exactly what you are doing step by step? I mean what buttons you press etc and I'll take the same steps here to try and recreate the problem.
When you insert the graph, do you see a blank graph at all? Or just a hollow box?
When you open the model, go to the screen of "Result summary_ water resources.VNN". Click on the "graph" button, then a new window get out asking me "New graph type?", I choose "Yes". After that, click on the screen to add a graph, then a hollow box appear on the screen. Right click on this hollow screen and choose "Properties", then Sabel died.Administrator wrote:Everything seems fine to me.
I attached a picture of the problem. Thank you.
- Sable stop working.png (50.86 KiB) Viewed 39204 times
ok, it looks like the graph component has not installed properly (the hollow window should show something).
Can you try reinstalling?
Hi Tony,Administrator wrote:ok, it looks like the graph component has not installed properly (the hollow window should show something).
Thanks for your kindly help. I reinstalled Sabel and it worked. Thanks again.
Kai
