Problems of executing Sable Script
Moderator: Administrator
cphan
Post by cphan »
I try to get subscripts from model by using the following scripts
Sub getSubscriptElements()
dim count as integer
dim value as string
count = GetNumberOfSubscriptElements("type")
msgbox ( count, "number" , MB_OK )
value = GetSubscriptElement("type",0)
msgbox ( value, "first value" , MB_OK )
value = GetSubscriptElement("type",1)
msgbox ( value, "second value" , MB_OK )
End Sub
When I run this script directly in Sable, I have count = 0 instead of 2. I have count = 1952922682, value = "getsubscriptelement("type",0) if I execute this script from the published file .spk.
Any ideas ?
Re: Problems of executing Sable Script
Can you send the SPK? I'm getting identical results from one I've created.
Regarding "count", what happens if you try
count = GetNumberOfSubscriptElements(type)
I've already put a fix in that will try removing the quotes for the next update of Sable.
cphan
Post by cphan »
By removing the quotes, it works now in Sable Developer. Thanks!
But I have always the problems with .spk file. I attach here my test project.
test.zip
(281.55 KiB) Downloaded 1991 times
cphan
Post by cphan »
Can I use the function GetNumberOfSubscriptElements with a string variable ? For example:
dim test as string
test = "type"
count = GetNumberOfSubscriptElements(test)
cphan wrote:Can I use the function GetNumberOfSubscriptElements with a string variable ? For example:
dim test as string
test = "type"
Yes, it should work fine. Are you having trouble?
cphan
Post by cphan »
No, it doesn't work. GetNumberOfSubscriptElements(test) returns the number of elements of the subscript named "test"
You are right. I'll have it fixed in the next version.
