Cumulative flow does not match stock
MKeeken
Post by MKeeken »
Dear,
I am modelling investments, but I encounter a problem.
The flow has the same value for every time step. However, the stock does not accumulate correctly... Only with timestep 1 does the stock have the same value as the cumulative flow. The stock does not accumulate correctly with smaller timesteps. It seems like some flow is fading away into mystery and not reaching the stock at all. Please see the attached screenshot of the behaviour in graphs of the stock and flow.
The equation for the stock (name stock: Cumulative investment primary) = incoming investment primary (flow). The initial value for the stock = incoming investment primary (flow).
The equation for the flow (name flow: incoming investment primary) = Investment primary aluminium (variable). This is a variable with some calculations.
How can I fix the model so that the stock has the same value as the cumulative flow with smaller timesteps (1/4 or 1/8)?
Looking forward to receiving the solution. If necessary, I can share some of the investment parts of the model.
Kind regards,
MKeeken
Screenshot 2024-03-26 134859.jpg (121.89 KiB) Viewed 18933 times
Re: Cumulative flow does not match stock
1. Does your model pass the units test?
2. Have you selected an appropriate time step? https://www.vensim.com/documentation/ref_time_step.html
It's impossible to comment further without the model.
MKeeken
Post by MKeeken »
Thank you for the fast reply!
The used timestep is smaller than the smallest time used. I worry mainly about passing the validation tests with changing values if the timestep is reduced.
Is it possible to share the model privately?
